texting issue
  • Updated 6 years ago
seem to be having texting issues...upon sending, it is quite delayed, 1-2 mins to send, upon receiving similar, attempted to delete some threads keep getting error message indicating "activity messagin (in application messaging) not responding...have turned if off for 1, 5 and 10 min intervals have had the battery out now overnight...help!!
Photo of Cynthia Hawley
Cynthia Hawley
Posted 6 years ago
Photo of HippieLongstocking
HippieLongstocking
  • 24,720 Points 20k badge 2x thumb
Hey Cynthia
is your outbox/inbox full
what type of phone do you have
Photo of LairdC
LairdC
  • 5,164 Points 5k badge 2x thumb
you could try a "hard reset". It's in your settings, depending on the phone yo have.
Cynthia Hawley
ooops, just realized i may have responded in the wrong sopt, sorry!! first time here :) is a hardset something that would disrupt/delete data i may have in an app on my phone?? not crucial info but related to gym activity i would record elsewhere before doing! thanks
Photo of LairdC
LairdC
Yes, you would lose anything on the phone, but not on your SD card if you got one. Save everything you can there before you reset your phone.
Cynthia Hawley
thank you!!
Cynthia Hawley
umm, sorry im not sure, im not that techno clever...i do know that i do not have any texting limits set if thats a reasonable answer?!? it is an LG Optimus from Koodo, Thanks!
Photo of Ahmad
Ahmad
Try quickly removing your battery and putting it back in and then try sending a text. The phone could just be 'clogged' and need a good reset
Cynthia Hawley
thank you but tried the battery thing several times, at several speed intervals from super fast to overnight!! grrrr, technology is great when it works, but apparently the end of the world when it doesnt :)
Photo of Ahmad
Ahmad
Are you just turning off your phone or removing the battery? the battery has to be removed
Cynthia Hawley
both, did the turning off thing several times over about a half an hour, and the battery and SIM card yanking thing several times last night before bed, then for the entire night...still the same
Cynthia Hawley
Photo of Ahmad
Ahmad
The only thing that would delete your data is if you went into the settings menu and actually did a reset to factory settings
Cynthia Hawley
hmmm, ok, good to know!! thanks
HippieLongstocking
once in messaging hit the menu metton button(its the the button on the left of the phone with the 2 squares one is white) make sure delete old messages is turned on and set text limit to something you prefer more then what its set to as it may be default which is 200, and sometimes this is the issue
always something to check
Photo of Yannick
Yannick
Hi Cynthia, if you're still having issues with text messages, you should contact our technical support so we can have a look at it. We can be reached at 1-866-995-6636 from a landline, option #6 :)
