Texting in Florida but suddenly stopped a week ago. Phone calls work though
  • Updated 6 months ago
Bought unlimited tallk and text for the US while in Florida. Worked ok but texting shows failed about a week ago. Turned off phone a couple of times but not fixed. Phone calls work. What is wrong?
Photo of June Roy
June Roy
Posted 6 months ago
Photo of Dinh
Dinh, Mobile Master
  • 42,136 Points 20k badge 2x thumb
hi June,
What phone are you using? could you try to take the SIM out and put it back again?
How was your incoming texts? Did they work?
Photo of David
David, Mobile Master
  • 93,788 Points 50k badge 2x thumb
Rember, buying a roaming plan does not change the behaviour of your phone. It only adjusts your billed costs.
