Test unlocked phone for network with current Koodo prepaid SIM?
  • Updated 2 years ago
I am considering buying an unlocked Nokia Lumia. and want to check that it works with my Koodo prepaid SIM. If I pop my SIM into the new phone, will that be sufficient to see that it picks up the network?  Anything I should be aware of?
Photo of Joanne Lozier
Joanne Lozier
  • 90 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Ray
Ray
  • 7,674 Points 5k badge 2x thumb
That should be enough. Koodo supports 850 and 1900 MHz bands on 3G/HSPA, and 1700/2100 MHz (band 4) on LTE.
If you plan to use data or picture messaging, you'll have to edit the APN settings. See http://aide.koodomobile.com/plans-add-ons-data-and-other-services/data/How-do-I-setup-data-on-my-Win... for details.
Photo of Ivan
Ivan, Mobile Master
Unless you get a really cheap Lumia model from overseas that has only dual-band 3G, it'll work on Koodo.
Which Lumia are you considering and where are you purchasing it from?
Photo of Danny
Danny
  • 3,454 Points 3k badge 2x thumb
Just stick it in and give it a try!
Joanne Lozier
Thanks for your input.  I'm getting a little squirrel-y now as it's a Kijiji seller, the phone is a Lumia 640 LTE. He says it is an AT&T phone, it's brand new and he just opened packaging to unlock it.  I smell a fish...
Joanne Lozier
Just to add... this is a Christmas gift for a 14 year old.
Photo of Daniel
Daniel, Employee
  • 5,702 Points 5k badge 2x thumb
Hi Joanne,
Just to be sure, you can enter the IMEI of the device on this link in order to confirm that it will work on our network: http://koo.do/1aU1u0o
Hope that helps :)
