Telus Note 2 on Koodo Network
  • Updated 6 years ago
I am looking into getting the Samsung Telus branded Galaxy Note 2 to be used on Koodo network. I read there for the Telus Galaxy Note and S3, there were APN issues which does not save the Koodo APN and it reverts back to Telus. I had a Telus S3 and it did not save the Koodo APN. Does anyone here know or using a Telus Note 2 if the Galaxy Note 2 have this same issue? I do not want to root the phone so don't suggest that.
Thanks.
Photo of Kevin Tam
Kevin Tam
Posted 6 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,312 Points 100k badge 2x thumb
I highly suggest you don't get a carrier branded Note 2 if your going to buy it outright. You should do what me & another forum frequent koodo member did & get the unlocked international model of the Galaxy Note 2 from an online retailer like expansys or Newegg.
You looking at the same amount of money but you'll have the huge advantage of getting updates months ahead of anybody with a carrier branded model. I am already running Android 4.1.2 & have had multi Window since day 1, where carrier branded models are just getting multi Window & won't see Android 4.1.2 for a month or more.
It is an HSPA+ model without LTE but you don't want LTE anyways right now especially if your not in an area with LTE coverage. The big downfall of LTE is its a major battery hog & after doing some tests between the 2 LTE cuts your battery life nearly in half of that of the HSPA+ model. It really isn't worth getting a Web page a second or two faster when you can only use your device for half the time before needing to recharge.
I've convinced a few ppl to go this way & they all say they are so happy they did.
Since the international model is already unlocked you just have to pop in a Koodo Micro SIM & away you go.
You might have to unlock the Telus Galaxy Note 2 so your looking at another $30 or so if you go that way so the model I'm suggesting is probably actually cheaper.
- KID ANDROID. ( Team.Android.Canada)
Photo of Don
Don
  • 6,586 Points 5k badge 2x thumb
Actually cheaper, some carriers will not let you purchase the device outright without paying for a least a month of service... Plus expansys and newegg regularly have free shipping and specials on the device.
Photo of Jacob Gellert
Jacob Gellert
  • 90 Points 75 badge 2x thumb
I have the n7100 with koodo but cannot get wi-fi hotspot to work? Any ideas
And speedtest.net app wont work either?
Jacob Gellert
Yes, Yes, Yes - Im not a noob :P unlike the name incinuates
  • 203,230 Points 100k badge 2x thumb
Speed test won't work unless you delete the proxy setting in your koodo APN settings
Jacob Gellert
Well that allowed me to do speed test but thats it. My laptop gets network connectivity but no internet.
Jacob Gellert
What speeds are you getting on the speed test on your n7100 KID?
I'll check next month, I'm at my limit for data & speed test takes a pretty large amount of data to do. What are you getting?
