Telus note 3 on koodo?
I have a Telus note 3 and I was wondering if I could use it on koodo with out unlocking it
Photo of Nick Klein-Beekman
Nick Klein-Beekman
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,938 Points 100k badge 2x thumb
No it would need to be unlocked to use on Koodo.
Photo of Mark Kokolsky
Mark Kokolsky
  • 10,722 Points 10k badge 2x thumb
Before spending money to unlock it, I would just try putting in the Koodo sim. Its easy and free to try, and there is a chance it may work. If voice/text works, then you may just need to edit the APM settings and put in the Koodo ones. If voice/text doesn't work, then you need to unlock it.
Photo of Ahmad
Ahmad
I think Paul's knows/had tried otherwise we would usually tell them to try it otherwise
