Tabs and changing rate plans
Ok, so I am using the $64 plan and want to move up to the$74 plan. I'm on a tab. How does the plan change work. And will it affect my tab.
Photo of Bradley Mc
Bradley Mc
  • 344 Points 250 badge 2x thumb
Photo of Ivan
Ivan, Mobile Master
  • 95,532 Points 50k badge 2x thumb
Moving to a more expensive plan will have no negative effect on your tab. Koodo will be contributing slightly more each month toward clearing your tab (15% of 74 instead of 15% of 64)..
  • 203,644 Points 100k badge 2x thumb
To change your plan simply log into self serve and click change my plan. The change is effective immediately.
Be careful though as your plan will be prorated and so will your available minutes.
Data however is not prorated.
On your next bill You'll see two plans billed. Your former plan up to the day you changed it
Your new plan up to your bill date
Your new plan to your next. Bill date.
Subsequent bills will be normal.
