T Mobile Note 2 no data
I just got an unlocked T Mobile Note 2 SGH-t889 and tried to get it on Koodo. Phone and text works fine. MMS and Data do not work. I set it up using this info here.
http://koodomobile.com/en/ab/non-kood...
Also brought it in to a store and they said that it is weird that the data isnt working but everything else is. Any ideas?
Photo of Andrew Sheppard
Andrew Sheppard
  • sad
Photo of Ivan
Ivan, Mobile Master
Try ignoring the proxy server.
Photo of mattjs
mattjs
  • 15,658 Points 10k badge 2x thumb
Tmobile US runs off an AWS 1700 band. I don't know enough about samsung products to comment specifically on the Tmobile Note 2, but have you checked to make sure the device is quad band with 1900/850 support?
Andrew Sheppard
It's a penta band phone so it's supposed to work on everything. The clearing of the proxy did not work either. Lame
Photo of Don
Don
  • 6,586 Points 5k badge 2x thumb
During my visits in Montreal and Toronto, I have seen many cell shops that offer the modification of cell phones from Wind to HSPA/GSM providers and vice-versa. Wind and TMobile run on the same frequencies, you could probably check with them if they can do this for you.
Photo of Ivan
Ivan, Mobile Master
I wish people would stop making blanket statements about AWS phones "not working" on other carriers. If Andrew didn't have a compatible phone, then he'd never have the ability to make/receive calls and SMS. It was clearly an APN issue.
Andrew Sheppard
I knew it was something other than the phone cause the Koodo people just said if it wouldn't work with data it would not work with anything else. Glad it fixed itself though.
Andrew Sheppard
ok so I seem to have got it to work. I just did a factory reset and bam... everything works fine. Din't change any settings or put in the koodo settings so hurray!
Photo of Ivan
Ivan, Mobile Master
Good to hear. Sometimes a reset is necessary.
