T989D Firmware not recognized in Kies
  • 2
I'm having problems updating. I have the T989D Koodo. I have
Android 4.0.4
Baseband: T989DTLLG2
Kernal: 3.0.8-perf-T989DTLLG2-CL836160 se.infra@SEP-89 #1 SMP PREEMPT Fri Jul 13 23:39:44 KST 2012
Build: IMM76D.TLLG2
I also have the latest Kies, as of today (13/05/13).
In Kies my phone's firmware version is not showing up at all, just a blank, and i can not find anything to fix it. I tried *#7284#, UART set at Modem, USB set at PDA. I re-installed Kies fully more than once. I want to update my android to 4.1.2.. Any help would be appreciated on how to make the firmware show up.
Thank you
Photo of Adrian Juhasz
Adrian Juhasz
  • 2
Photo of MatB
MatB
  • 32,458 Points 20k badge 2x thumb
Hi Adrian !
There were 20 posts on previous similar post http://community.koodomobile.com/kood...
Adrian Juhasz
None of that helps me. I went threw it a few times before I posted. My problem is different and i can not find anything on the internet. My phone is recognized by the computer and it shows up in Kies. But when it's connected the Current Firmware does not appear, it is just a blank. I does not say i have 4.0.4 . currently on it so there is no way for me to prompt for an update. Nothing appears under any firmware option. On the other hand is it possible for me to take it to koodo so they do my update to 4.1.2?
Photo of rikkster
rikkster, Mobile Master
  • 66,988 Points 50k badge 2x thumb
Flash the firmware via Odin, obtain the firmware from SamMobile - there are a number of tutorials on how to flash firmware onto your S2x/T989D. Enter SGH-T989D in the "Search device here" box to the right of the page. You will have to register with SamMobile first.
http://www.sammobile.com/firmwares/
Get Odin here: Version 1.85
http://forum.xda-developers.com/attac......
If that doesn't work, try version 3.07
http://forum.xda-developers.com/showt...
Photo of Rob MacKay
Rob MacKay
  • 252 Points 250 badge 2x thumb
Apparently the Jelly Bean upgrade for the T989DTLLG2 Baseband hasn't been released yet.
Photo of rikkster
T989DTLLG2 is for ICS version 4.0.4, you want PDA version T989DTLUMC4, which is 4.1.2 JellyBean. I'm experimenting with reverting back to the stock ICS radio (running JB 4.2.1) so that I can regain mmi/ussd functionality.
Stock ICS Koodo Radio
Stock ICS Telus radio - click black/white d/l button
http://api.viglink.com/api/click?form...
