System not accepting my SIM card number
my daughter put my phone in the pool and now I can't put my older koodo phone on the system because it wont accept the sim card number. I never reported it lost or stolen, so why is this happening
Photo of Rachel Hill
Rachel Hill
  • sad
Photo of Reena
Reena
  • 4,244 Points 4k badge 2x thumb
Usually if your sim card hasn't been used in a while it won't allow you to re-register the sim. It should work if you have a new sim.
Rachel Hill
This is a 3 month old phone. I have no other SIM cards or phones and I cant even call csr. I am 2 hours from a repair centre. Guess I'm outta luck!?!
Rachel Hill
its an lg, it slides. it says lg c550 under the battery cover
Photo of MykeC
MykeC
  • 20,174 Points 20k badge 2x thumb
If it doesn't have a sim card that was used within the last 90 days, then you will need to purchase a new sim card.
________________________
Rachel Hill
Its been over 90 days. are they universal though. If I go in to, say walmart, can I buy a sim card there if they sell koodo phones?
Photo of MykeC
MykeC
Yes, you can purchase a new sim card if the Walmart sells Koodo phones. It's best to call in advance to be sure that they carry them.
Rachel Hill
well i cant call in advance because I have no phone lol oh well. I will make a drive tomorrow. Thanks for the advice :)
