switching phones
If I were to update say from an iPhone 4 to an iPhone 5. And I bought the new phone from Apple, can I just take out the sim card and put it into the new phone?
Photo of Jessica Prytulka
Jessica Prytulka
  • 210 Points 100 badge 2x thumb
Photo of Dennis
Dennis, Mobile Master
  • 187,420 Points 100k badge 2x thumb
Yes you can, Except that the 4 uses a micro sim and the 5 uses a nano sim card. You would need to buy a nano sim for $10 and it should work :)
Jessica Prytulka
okay thanks! I don't need to inform koodo that theres a different phone on the account or anything like that?
Photo of Dennis
No need to inform them. They dont care what phone you use or where you got it from.
When you get the new dim you just need to switch to the new sim via self serve.
You could switch back to the original sim to use the iPhone 4 if you want too. Just FYI, a sim card is permanently disabled if there is no activity on it after its been used
Jessica Prytulka
thanks very much!
Photo of Dennis
You're welcome :)
