switching phones ?
I cracked my screen on a pre paid koodo phone, and I found a used prepaid koodo phone. How do i switch phones ? Can i just put the chip in and use it ?
Photo of kimberly mike
kimberly mike
Photo of Dennis
Dennis, Mobile Master
  • 177,700 Points 100k badge 2x thumb
Sure, if they use the same size sim card you can do that.
Otherwise, you can buy the corrected sized sim card for the new phone and transfer to the new sim via self serve
Photo of Jru Gordon
Jru Gordon
  • 9,018 Points 5k badge 2x thumb
just an addendum, when you put the SIM in, make sure the phone is off, put the SIM in, turn the phone on, and it should work. If not, just call Koodo and tell them the new IMEI number and they should easily switch it over
