Switching phones
I have a S3 and I was wondering if I could switch the phone but keep the plan and everything the same.
Photo of Nicky Vanrivong
Nicky Vanrivong
Photo of Sophia
Sophia, Mobile Master
  • 140,672 Points 100k badge 2x thumb
Yes! Definitely, Nicky. You can even get a new phone on a Tab (Small Tab if your plan is below $30, Medium Tab if your plan is above $30).
Photo of B2theden
  • 2,626 Points 2k badge 2x thumb
Are you buying the phone off koodo? If so then are you putting the phone on the tab? Because if you are and you plan is for a certain tab and you get a different tab then no, but if you Are on a tab small plan and get your new phone paid in full or still on a tab small then yes you can. If you are on a tab small plan and you buy a new phone and put it on a tab medium then no you cannot keep the same plan.
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
You can keep the same plan if the plan is over $30/month it only adds a $5 tab charge to the account if you go to a tab medium.
Photo of John Lee
John Lee
  • 36,704 Points 20k badge 2x thumb
Get a new phone, get a new SIM card if needed, switch, simple!
