switching from a bb curve to a bb z10... HELP
I currently have a BlackBerry curve and I am switching to a BlackBerry Z10. How do I switch my sim card and stuff?
Photo of Enya McKenna
Enya McKenna
Photo of Ivan
Ivan, Mobile Master
Check out the guide from BlackBerry: http://ca.blackberry.com/support/tran...
You can use the BlackBerry Link software to transfer personal content between phones. I believe that your Curve uses a now obsolete mini-SIM whereas the Z10 uses a newer micro-SIM so you'll need to pick up a new SIM card. You can switch the SIM card registered to your line via the Phone tab in Self Serve. If you're buying a new Z10 from Koodo, you should be getting a new SIM card along with it. If getting a used one or buying elsewhere, you'll need to buy a micro-SIM from Koodo or an authorized retail partner (BestBuy, Mobile Shop, etc.). It's $10 for postpaid (monthly) or $20 for prepaid.
