Switching Phones
I have a koodo prepaid and a koodo monthly phone. I need to replace my monthly failing phone with my prepaid that is no longer in use, can that be done by switching the sim card from my monthly to my prepaid?
Photo of Cliff Lush
Cliff Lush
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Yes if it fits (same size SIM Card) then you can use your prepaid phone on your postpaid account, just switch the SIMcCard and away you go. If it's a different size then you will have to go get a new postpaid SIM Card that's the right size
Photo of Chris Petersens
Chris Petersens
Better answer than mine. 
Chris Petersens
I'm pretty sure all you have to do is swap the SIM from your monthly to your prepaid koodo phone. SIM contains all your info for your account. It should work.
