switching phones between 2 accounts
  • Updated 6 months ago
My wife and I, both LG phones, wish to switch our phones. Do we just have to switch the SIM cards from one phone to the other, or is it more complicated?
Photo of Robert De Gols
Robert De Gols
Posted 6 months ago
Photo of Allan
Allan, Mobile Master
  • 56,526 Points 50k badge 2x thumb
Just as easy as switching the sims!
(Given both phones currently with Koodo/Telus or unlocked)
Photo of Pedro Echeverri
Pedro Echeverri
  • 500 Points 500 badge 2x thumb
Just switch the SIM cards into the new phone and your back and running.
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
Hi Robert,
If you are both with Koodo/Telus/Public Mobile, then yes it is that simple! :)
If the phone is locked to a different provider, then you will need to get them unlocked first.
Photo of Dinh
Dinh, Mobile Master
  • 32,650 Points 20k badge 2x thumb
Hi,
Yes, you would just need to switch SIM.
However, if you want to switch sms, contacts and data from one phone to another, then it is more complicated.
Photo of Allan
4 posts within 9 seconds of each other...thats a new record xD
