Switched from blackberry to moto g - having issues HELP!
I recently switched from a blackberry to the moto g. I've had it for a day and didn't realize that apps continue to run in the background and now I've basically demolished all of my data for the month. How do i stop apps from running in the background and automatically updating?
I really only want to be able to use facebook, text, google, and email on a consistent basis :S
HELP please!
Photo of Amanda Carruthers
Amanda Carruthers
  • 90 Points 75 badge 2x thumb
Photo of G@R¥ S.
G@R¥ S.
  • 216 Points 100 badge 2x thumb
If you go to:
- setting
- Data usage
you will be able to see you data usage and all the apps that contribute to that data usage. Tapping on the app will give you the option of diabling background data usage.
Auto update for the apps and is done over wifi only so that shouldnt inpact your network data.
For the software update go to:
- Setting
- About phone/ debive
- Software update
There you will be able to set how your phone will update the software.
Hope that helps.
Photo of Daniel Kim
Daniel Kim, Mobile Master
great answer, but on some phones, apps are set to update over data or any connection that is available. To set apps to update on only wifi, you have to; go to the playstore app>playstore settings>auto update apps>set it to wifi only.
Photo of matthew sider
matthew sider
  • 746 Points 500 badge 2x thumb
Software up dates can worsen the phone may make
the phone higher android is like a computer
is by saying that on the medle of the there should be a
butten then clear apps is the way won't run in the back round what stupid that make this with out thinking
for charging clear apps runing back round
  • 203,644 Points 100k badge 2x thumb
Under data usage, hit the menu dots, Uncheck background data.
Next you'll need to open each app you talked about and Uncheck the auto update part of that particular app.
Amanda Carruthers
Thanks everyone...very helpful!
