Switched from Telus to Koodo and iPhone to Samsung, texting is an issue
  • Updated 12 months ago
I have tried disabling iMessage but no dice. It seems that the few folks that I cannot receive texts from are iPhone users, though not all of them. (My roommate has an iPhone and I receive her texts just fine). Any help or advice would be much appreciated!
Photo of Samantha Dawn Knee
Samantha Dawn Knee
  • 80 Points 75 badge 2x thumb
Posted 12 months ago
Photo of Allan
Allan, Mobile Master
  • 56,526 Points 50k badge 2x thumb
Tell your friends to delete the conversation they have from you and then try texting you and see if it works.
Can you text them, they just cant text you?
Samantha Dawn Knee
Yep, I can text them. Their texts aren't getting to me. I will give that a go.
Photo of Allan
Also did you disable iMessage while the sim was in the phone? If not, put the sim card in first, then disable it as mentioned here: https://support.apple.com/en-ca/HT204270
Photo of David
David, Mobile Master
  • 89,014 Points 50k badge 2x thumb
And be sure your iPhone using friends are sending messages to your phone number, not your iTunes ID.
Photo of Robert
Robert, Mobile Master
  • 103,604 Points 100k badge 2x thumb
If you don't have the phone anymore, you could always try that : https://support.apple.com/en-ca/HT203042
Photo of Dennis
Dennis, Mobile Master
  • 187,208 Points 100k badge 2x thumb
Try rebooting you're phone
