Switch my Hub which I own to Koodo
  • Updated 5 months ago
  • (Edited)
Want to switch my Rogers Hub which I own over to Koodo and retain my home phone number which is used on this Hub. Then all my phones will be on Koodo and on the 1 billing. Will the $5.00 offer apply?
Photo of John Weston
John Weston
  • 82 Points 75 badge 2x thumb
Posted 5 months ago
Photo of Allan
Allan, Mobile Master
  • 62,896 Points 50k badge 2x thumb
Yes, you can port your Rogers number to Koodo and get the $5 offer.
Photo of Dennis
Dennis, Mobile Master
  • 196,890 Points 100k badge 2x thumb
The Rogers hub might be locked to Rogers and will not be usable with Koodo.  However you can try testing it out
John Weston
Can this Hub not be unlocked from Rogers the same as a smart phone.
Photo of Dinh
Dinh, Mobile Master
  • 42,136 Points 20k badge 2x thumb
hi John,
You need to make that inquiry to Rogers. I think the hub could be categorized as a phone, so it is eligible to be unlocked by CRTC. I think they are also selling unlock code on ebay.
