Swipe not working for texting, but says it is on!!!!!!
I got a Samsung Galaxy 2 and it says that the swipe is on when you text, but I try to use it and it will not work, what am I doing wrong!
Photo of Pat Smith
Pat Smith
  • 80 Points 75 badge 2x thumb
Photo of John Burke
John Burke, Mobile Master
Are you using the proper keyboard?
Go to Settings--> Launguage & keyboard--> and set Swype as the default keyboard.
Photo of Pat Smith
Pat Smith
tried this and cannot get it!
Photo of Myke
Myke
I recommend Swiftkey for your swiping. Very easy to use once you set Swift as your default keyboard. Set up is really easy as well.
Photo of rikkster
rikkster, Mobile Master
  • 66,988 Points 50k badge 2x thumb
Swype is no longer a part of the Android operating system. Makers of the popular gesture-based keyboard software Nuance, started a public beta for select Android devices back in mid-June 2010 and exited beta in late April 2013, the software became available for download shortly thereafter.
Swype was replaced by Samsung's own version known as Keyboard swipe. Samsung's version is severely limited and both Swype and Swiftkey are available for download from the Google Play Store. Both offer a trial before you buy option. Trial version links below.
https://play.google.com/store/apps/de...
