Stuck in emergency call mode
Just got my new Moto g yesterday. was working fine until I needed to charge the battery. Now it seems to be in emergency call mode and I don't know how to get out of it to make the phone work again! HELP!
Photo of prettygirl1
prettygirl1
  • 180 Points 100 badge 2x thumb
Try going to
Settings
Wireless And networks
More
Mobile Networks
Make sure Use 2g only or Use GSM only aren't selected
Also be sure network selection is
Gsm/wcdma preferred
Or
Gsm/wcdma auto
prettygirl1
I can't do that, Chad! The reason I asked for help was because I can't get out of this mode to menus or anything! Using a Moto g...turned it off to charge and now it just has an emergency call number keypad on the screen....Never mind...it was locked some how...unlocked and now working!!
Had you mentioned that there was a keypad on the screen my answer would have been different.
Good to hear you have it working
Enjoy your MotoG
Photo of Rohit Bhadala
Rohit Bhadala
  • 60 Points
Bought new moto g and and no network on the phone but it shows d card being there.. Just no range.. Used d sim card in a different phone n it works
Photo of Enrique Verano
Enrique Verano
  • 60 Points
On mine I fix the same problem by removing the sim card and wipe it clean on the contacts side with a dry napkin.
