Sony Ericsson C510a MMS Settings
  • Updated 4 months ago
  • (Edited)
I have an unlocked Sony Ericsson C510a phone compatible with Koodo - it is HSPA and everything is working except for MMS. I am not quite familiar with the MMS and APN settings on these older Sony phones as there are TONS of options. I've found a few sites and forums but i'm still left in the dust. Any ideas? Thanks!!
Photo of sheldance
sheldance
  • 90 Points 75 badge 2x thumb
  • hopeful
Posted 4 months ago
Photo of Allan
Allan, Mobile Master
  • 57,086 Points 50k badge 2x thumb
What error are you getting when you try to send a MMS? Do you have data enabled?
Here are Koodo's apn settings:
https://www.koodomobile.com/help/sett...
Photo of sheldance
sheldance
Thanks, Im aware of these settings, it's just that the way the Ericsson phones ask for the settings differs from Android and iOS devices. It just asks for different things.
Photo of Allan
  • 56,746 Points 50k badge 2x thumb
Could you take some screenshots of what you have so we can see what you're working with?
Btw, when you put in a Koodo SIM it should automatically configure this. To use MMS you need to have data enabled? Do you have data turned on while trying to send?
Photo of sheldance
sheldance
It won't automatically configure - this is a bar phone from 2009 that was not originally from Koodo so it requires some additional settings. Will post a photo!
Photo of Dinh
Dinh, Mobile Master
  • 32,882 Points 20k badge 2x thumb
The phone is properly an old phone that had troubles with automatic settings. According to gsmarena, it doesn't support LTE. https://www.gsmarena.com/sony_ericsson_c510-2640.php
I would suggest you follow Allan post and enter Koodo APN parameters. Also you need to enable mobile data for MMS to work.
