Some Tweaking Required
My sons Huawei Ascend P7 is not making a data connection. The APN settings are as follows:
Name - Koodo SP
APN - sp.koodo.com
Proxy - Not Set
Port - Not Set
Username - Not Set
Password - Not Set
Server - Not Set
MMSC - http://aliasredirect.net/proxy/koodo/...
MMS Proxy - 74.49.0.18
MMS Port - 80
MCC - 302
MNC - 220
Authentication Type - Not Set
APN Type - internet+mms
APN Protocol - IPv4
APN Roaming Protocol - IPv4
Bearer - Unspecified
MVNO type - None
And the mobile data is turned on. If anyone knows about this phone, or can suggest what else needs setting, all help is appreciated. Thanks in advance.
Photo of flyersfan
flyersfan
  • 1,654 Points 1k badge 2x thumb
Set apn type to default
Photo of flyersfan
flyersfan
No Luck. Still not receiving pictures.
Are you using the stock messaging app? Or hangouts? Or some other third party app like gosms pro?
And data isbt blocked right?
Photo of Ivan
Ivan, Mobile Master
I no longer own an Ascend P7, but when I did, the MMS worked. Can't remember what I had to do, but just wanted to let you know that there's hope.
Photo of flyersfan
flyersfan
Hope is GOOD..... a solution is BETTER. ;-)
Photo of flyersfan
flyersfan
Update Time. According to my son, he is using the phones stock messaging. No Hangouts type apps are being used. Data is enabled. Is there another setting to check that could be blocking data? The mystery continues..........
Photo of Not Jeff
Not Jeff
  • 2,058 Points 2k badge 2x thumb
The APN type needs to have the full value in there.
I believe there is a third value supposed to be inputted.
Also, check your plan. If there is a data block on your account (check in your self serve online), or by calling *611.
The Huawei phones are sensitive to the APN type being perfect. Most other androids can figure out the order of the APN type. Huawei can not. It must be put in perfectly. It make need the DUNS or DUPL inputs in there.
