Texts come in two minutes early
  • 2
  • (Edited)
I have the Samsung Galaxy Ace 2 X and every time I receive a text message it comes a minuet early. Like if the time on my phone says 8:00, l get a text saying it is 8:01 so when I reply at 8:00 it will go behind the other one, so my messages are all mixed up. How do I fix this?
Photo of Deanna Hubley
Deanna Hubley
  • 80 Points 75 badge 2x thumb
  • Angry, Annoyed
  • 2
Photo of Chris Petersens
Chris Petersens
Change the time to "automatic date and time" in your settings. Once you clicked on setting under "systems" you will see "date and time" . Then check the automatic thing.
Photo of Jaime Grant
Jaime Grant
that worked
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
If that doesn't work then whole the device is on take out the battery and SIM Card for a minute or so then replace them and try it again.
Photo of mwlewis63
mwlewis63
  • 90 Points 75 badge 2x thumb
The koodo network is two minutes slower then the world clock. So you will have to uncheck the automatic date and time add two minutes. To the time.
If the phone is using the automatic time it will use it for everything so that's incorrect. I have used auto network time through many phones and it's the right time all the time as well.
Photo of mwlewis63
mwlewis63
Never had a problem with my time or text until tonight...all text coming in were one to two minutes off...compared phone network time to world clock and guess what. ..a two minute difference. ...so either everyone sending me a text is off two minutes or my (auto update) was two minutes slow.
Chris Petersens
You are right man!!!! Very strange. Particularly because koodo runs off the telu network. We have a telus phone and a koodo phone in our home. There is 2 minutes difference between the two. The koodo one is slower. The telus one matches the world clock time.
Photo of Zeta Abramovic
Zeta Abramovic
  • 2,244 Points 2k badge 2x thumb
We have the same issue. Our koodo phones are behind.
Jaime Grant
my Koodo s2x is 4 minutes fast
Photo of Bernard
Bernard, Official Rep
  • 75,648 Points 50k badge 2x thumb
Folks, we are investigating the issue. Thanks for bringing it to our attention!
Photo of zacho
zacho
  • 162 Points 100 badge 2x thumb
Subscribing.
Photo of Robert
Robert, Mobile Master
  • 103,858 Points 100k badge 2x thumb
I've had the same problem here peeps. I've missed my bus because of this :P
I've turned on the set-automatically and it solved the issue for me!
Chris Petersens
It's fixed now. It aligns with the world clock.
