SIM & IMEI activation problem.
I think I may have entered the wrong IMEI number with SIM card # when activating online. My phone will connect to the network but says it is active in my Koodo selfserve profile. Does this mean I have to buy a brand new SIM card?
Photo of Jay
Jay
  • 90 Points 75 badge 2x thumb
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,110 Points 100k badge 2x thumb
It can take a little time for your device to become active. If your device has a removable battery then try doing a battery and SIM Pull, while the device is on take out the battery and SIM Card for a minute or so then replace them and try it again. This can sometimes jump-start your network connection.
If your device isn't active within an hour or so then try logging into your self serve and try inputting your SIM card # again.
Photo of Jay
Jay
Thanks for the speedy reply.
I tried the pull method and it didn't work.
I believe that I entered the wrong IMEI # when activating the SIM card.
Would Kodoo be able to fix this problem internally or would I have to buy a 2nd new SIM card in as many days?
I'm going to be unhappy if I have to buy another $20 SIM card before I even placed a phone call on Kodoo's network.
No your fine just call Koodo later today when customer service is open and they'll be able to help you out with activating the SIM Card you already have.
Photo of Jay
Jay
Thats great to hear.
Thanks for your reply again.
You just saved me from being stressed out over this all night.
You're awesome!
