SIM card is not working after LG G4 in water for a few seconds
  • Updated 4 months ago
My SIM card is not working after LG G4 in water for a few seconds. I immediately got it out of the water, and placed the phone into rice. Now the phone is fine, except for the SIM card. It's either giving me a no SIM card message or no service.
Photo of Mary Davidson
Mary Davidson
  • 180 Points 100 badge 2x thumb
Posted 4 months ago
Photo of Dinh
Dinh, Mobile Master
  • 33,054 Points 20k badge 2x thumb
Mary,
The SIM card is quite resilient to water. I think the problem was due to bad contacts inside the phone. I would try to test the SIM in another phone and see if the SIM works there first. If it doesn't work, then it is time to change SIM.
Mary Davidson
Thanks. I actually bought a new SIM card today, and that one doesn't work either.
Photo of Dinh
Dinh, Mobile Master
  • 30,692 Points 20k badge 2x thumb
Have you activated the new SIM?
Mary Davidson
Yes, it's activated. I think. I bought it at a Koodo location.
Photo of Dinh
Dinh, Mobile Master
By activation, I meant they transferred your old number into the new SIM?. Did you see the agent at store did it? normally they would need your number, your ID or PIN number to do it.
Once your new SIM was activated, the old SIM is disabled.
Mary Davidson
I think they did. She had my number and my ID. I think I'm going to call Koodo and check.
Photo of Dennis
Dennis, Mobile Master
  • 184,940 Points 100k badge 2x thumb
If the sim card is not the issue, it might be your phone that could be the issue
