SIM activation problem with Blackberry Bold
I just bought a Koodo sim card and monthly plan ($30/mo., no data) to use with an old, unlocked Blackberry Bold.
The problem is: when I try to make a call, I get a message that says I'm roaming and won't allow me to make the call. I also can't send or receive texts.
When plugged into another phone, the sim card shows the messages I received, so it seems the problem is getting the sim to work in this phone.
How do I get the sim card/phone combination to recognize the Koodo network?
Photo of Emma LeClerc
Emma LeClerc
  • 162 Points 100 badge 2x thumb
Posted 3 years ago
Hi Emma, what carrier was the bold originally. Locked to? Are you sure its unlocked now? Can you provide the full model number (located under the battery)
Emma LeClerc
Hi Chad,
The phone was originally locked to Verizon and is a Bold 9650. I unlocked it with Verizon Global last week, and called them last night to verify. When I turn the phone on, it says "Initializing SIM" and I can navigate to the SIM ID number, which the Verizon rep said means the phone is recognizing the card.
Emma LeClerc
I took it to a Koodo kiosk in St. John's.
Photo of Ry
Ry
  • 5,552 Points 5k badge 2x thumb
Unfortunately not. They are Bell and use the same frequencies as Telus/Koodo. Rogers / Fido are your only options.
Newfoundland, i can see why you are avoiding Rogers
Photo of Justin Robichaud
Justin Robichaud
  • 5,002 Points 5k badge 2x thumb
Ouch so Rogers/Fido must not really be a good option for you. I know Rogers network isn't great at all in Newfoundland.
Emma LeClerc
Yeah...
Justin Robichaud
I feel your pain Emma.
Emma LeClerc
If it helps, the error message when I try to send a text is: "(SMS error 97, Message ID 14) Service denied"
Photo of Ry
Ry
Hi Emma,
The issue is this particular model doesn't support the correct frequencies to connect with Koodo. It would could with Rogers/Fido on their 2G network (which is fine for voice/sms only), as Chad replied
Photo of Ry
Ry
Photo of Ry
Ry
Oops. Wrong thread I replied to
Justin Robichaud
Her issue will most likely be service. As Rogers/Fido network really stinks in Newfoundland.
I work at Future Shop in New Brunswick. I feel her pain! Rogers isn't great around here. I seldom sell them for that reason.
Photo of Ry
Ry
I hear you. Rogers is pretty much nonexistent on the East Coast, imho
Justin Robichaud
Pop into the store. Tell them what's going on.
Like Chad mentioned above, if you're within 15 days you can cancel the plan no issue. If they become aware that it was their mistake, they might even refund you for the SIM Card. At least I know I would if I made that same mistake, I can't speak for them though.
It's worth a shot!
Why don't you pick up a q5 at WalMart. You will be amazed and wont have to deal with all this .
Justin Robichaud
They're cheap too!
Emma LeClerc
What's a q5?
Justin Robichaud
One of the, sort of new, Blackberry's. They will come in a "Prepaid" box. Most retailers should carry them.
If I was in at work right now I'd check Future Shop Newfoundland for stock on something. They could be worth a shot!
It runs circles around your bold and doesn't require a special plan.
Emma LeClerc
Thanks, I'll look into it. The lure of this (hand-me-down) Bold was that it's free, but free is much less appealing when it's only compatible with a network that has such limited coverage here.
Justin Robichaud
I hear ya on that one!
Keep us in the loop with what you figure out and if you have any more questions or concerns feel free to ask!
Emma LeClerc
Will do!
Emma LeClerc
Thanks, everyone! You guys have been extremely helpful.
Emma LeClerc
I ended up buying a Samsung Galaxy S III at Koodo. It bumped my plan up to $30/mo. but that's alright. The sales rep refunded the money for the sim card when I told her what had happened, luckily. All is well.
Justin Robichaud
Great to hear everything is good!
