several calls are going right to voicemail ....they are not on reject list.
  • Updated 2 years ago
several calls are going right to voicemail ....they are not on reject list. They do not show in call list. What is going on? I can't miss calls! I have an samsung phone
Photo of jocelyn carter
jocelyn carter
Posted 2 years ago
Photo of Dennis
Dennis, Mobile Master
  • 196,652 Points 100k badge 2x thumb
How's your signal?
jocelyn carter
signal is fine
Photo of Dennis
Try rebooting the phone
Photo of Chadwick
Chadwick, Mobile Master
  • 33,092 Points 20k badge 2x thumb
Try rebooting the phone without the Sim in it. So turn it off, remove the SIM, turn it back on without the SIM in the phone. Turn the phone back off, put the SIM back, and reboot the phone. See if this helps.
jocelyn carter
I have done that
jocelyn carter
I just did so will see if it works
thanks
Photo of BobTheElectrician
BobTheElectrician
  • 67,578 Points 50k badge 2x thumb
Try sending yourself a text. That will verify that the network loop from and to you is in order.
You can't entirely rely on bars to show your signal strength. Go into your device settings and check status. Should give you a signal reading in -dB units for signal strength. You should have no problem if your reading is between -95 and -55. Any number over -100 will give you sporadic service.
jocelyn carter
i turned off, removed sim card and put back in and seems to be okay now.
In terms of signal the phone is doing this when it is in a usual location where I have no issues.
so it's just odd.
hopefully it is fixed
Photo of Chadwick
Glad it helped Jocelyn. Keep us informed if it goes back to not working.
jocelyn carter
thank you
