Settings for MMS or APN.
  • 2
Hi! Anyone can tell me if I need to change APN setting for Koodo if Nexus4 previously been used with Rogers...
Photo of Victor Demko
Victor Demko
  • 168 Points 100 badge 2x thumb
  • 2
You should check them against the correct settings
APN: sp.koodo.com
Proxy server: 74.49.0.18
Port: 80
Username:
Password:
Server:
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
Port: 80
MCC : 302
MNC : 220
APN type :
Victor Demko
Is there and app for Android you can recomend that can set everything for koodo or any carries I need?
And what happens if I don't/didn't change settings: Nexus4 asks t reboot each time SIM card changed because it might resets network settings?
Victor Demko
Koodo or any mobile carriers, I meant.
Photo of Adam Corbeil
Adam Corbeil
  • 60 Points
the app for android you are asking about is called Tweakker
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 202,996 Points 100k badge 2x thumb
Just make sure the phone isn't set to 2g or GSM Only because Rogers is the only carrier in Canada that is GSM/2g.
Photo of Ivan
Ivan, Mobile Master
And their subsidiaries.
Victor Demko
I am kind lost there.... Koodo is not GSM?
Photo of Jonathan I
Jonathan I, Mobile Master
It is but it uses strictly HSPA.
Some older Rogers/Fido phones, like the Blackberry 8520, are GSM/use a SIM card but don't use HSPA, only what is called "2G" or "EDGE" only. Even if you unlock the phone, it will not work on Koodo because they do not support that kind of technology. Koodo had an identical model, the 8530, but it is CDMA - it had to be so it could work on Koodo's network.
Telus/Koodo and Bell/Virgin only used CDMA (no SIM card) for a while and then went over to HSPA SIM card phones. Rogers/Fido never had CDMA and always used SIM cards, however it was 2G/GSM-only/EDGE and went up to HSPA (3G+) afterward.
Victor Demko
Thanks
Photo of David Whalen
David Whalen
  • 60 Points
Thanks, helped me too coming from Telus
Photo of silawat s
silawat s
  • 60 Points
Thank you for your information. It is working now.
I bring my iPhone 5 from Thailand. I bought Koodo prepaid sim in Vancouver. Register and buy data pack for 1 GB. It did no work. I called to call center. The agent explained to me to set APN.
This is how to set APN via iphone configuration utility.
http://support.apple.com/kb/HT4839?vi...
This is the software to download:
http://support.apple.com/kb/dl1466
Now it working!!!!
Thanks again
