Set up roaming (with intn'l voice/data). Still can't call Canada from Costa Rica
  • Updated 5 months ago
Used Self Service, got roaming turned on. Got the text msg from Koodo after I arrived in Costa Rica. Apparently, from comments on this website, I should have got the msg and followed the instructions *before* I left Canada.
So, can this be fixed, or have I wasted my money?
Using an HTC Desire 320. Android v.4.4.2
Photo of Orrin
Orrin
Posted 5 months ago
Photo of BobTheElectrician
BobTheElectrician
  • 67,216 Points 50k badge 2x thumb
Not familiar with your particular handset, but for generic Android: Check the network mode on your phone and de-select LTE. Some carriers there don't support it. Leave network provider as automatic. Restart your phone.
Photo of Dinh
Dinh, Mobile Master
  • 41,662 Points 20k badge 2x thumb
From this https://www.gsmarena.com/htc_desire_320-6913.php
The HTC Desire 320 is quite a basic smartphone, No LTE... and limited 3G bands
Photo of Dinh
Dinh, Mobile Master
Hi Orrin,
So just to confirm, you had easyroam voice and data roaming add-on already.
Can you text to Canada at all? How about data? can you access internet from there with your phone?
First, I would try to restart your phone, and see if it helps.
Photo of Orrin
Orrin
I am able to connect to the Internet with my tablet. I did the reboot but no go. Trying a txt msg now. Annnd just got a reply. But still no phone calls. I can connect to the Net via browser.
Photo of Dennis
Dennis, Mobile Master
  • 196,026 Points 100k badge 2x thumb
So your phone can connect to the internet via cellular data?
What does your tablet have to do with your phone?
What happens when you call?  Is there any warning about Call barring?
Photo of Dinh
Dinh, Mobile Master
@Orrin:
Can you check if your phone was connected to Mobile network and not Wifi.? are you using your tablet with wifi? What was the name of the local roaming there?
You could received a text message back, and hence the phone was connected to a network. Have you tried to ask someone (from canada) to call you? and can you call a local number from your cell?
BobTheElectrician
Check out:
https://www.howtocallabroad.com/
to make sure your keypad coding is correct.
Photo of Orrin
Orrin
Found out I'm supposed to enter 00 1 before the area code. (I was not entering the double zero.)
But it didn't help..
Thanks for the useful information, though.
Photo of Dennis
Are you able to connect to a network?
Photo of Orrin
Orrin
See reply to Azure. That is, yes. I can.
