service problem
  • Doesn't Need an Answer
We Just switched to koodo today and love it but when at home my husband has service and I have nothing. Have u ever heard of this. I'm stinking mad.
Photo of Colin and Nicole Peever
Photo of Daniel Kim
Daniel Kim, Mobile Master
Try rebooting your phone or resetting network settings. Make sure you have 3g enabled :)
Photo of John Lee
John Lee
  • 36,704 Points 20k badge 2x thumb
Do you just have "No Service" or is there a SIM card available? If your husband has service, you should have service as well.
Try performing a battery reset which is turning off your phone, taking out the battery, sim, sd card, etc., waiting for about 30 seconds - 1 minute, then putting everything back together and restarting the device.
Sometimes a battery reset solves some issues. Also, make sure that you aren't on 2G. If all fails, you may want to contact Customer Care. It may be a faulty SIM.
