Sending MMS on Basic Prepaid seems to require data
Sending MMS failes with basic prepaid plan unless I enable mobile data but basic prepaid includes unlimited text and picture messages. Shouldn't I be able to send a MMS without a data booster?
PS - I'm using a Moto G
Photo of Paul Calamai
Paul Calamai
  • 340 Points 250 badge 2x thumb
  • frustrated
Photo of Chris Petersens
Chris Petersens
That's right. And it does. But you do have to have data access turned on on your phone. There is no charge for send pics though.
Paul Calamai
Confused...are you saying that I can turn data on without having a data booster or are you saying that I have to have a data booster but that sending the MMS will not reduce my data quota?
Chris Petersens
You do have to turn data on your phone for the pics to be sent. You do not need a data booster. Even if you buy one it still doesn't it into your quota. Other app running in the background might though, so always disable those or just set for wi-fi only.
Paul Calamai
Cool...thanks
Photo of Rocky Balboa
Rocky Balboa
Data is required to use MMS. Unfortinately you would need a data booster...
Chris Petersens
Not true. Their website states explicitly that unlimited messaging inludes text and picture. Nowhere it states you have to buy a data booster.
Rocky Balboa
Sorry cannot edit post Chri sis correct you should just need to enable the data on your phone.
