sending text's don't work but receiving works!
  • Updated 6 months ago
I have the bluboo s1, I did a post before here about data not working and I got it why but now texts dont work on my new phone, the bluboo but it doesnt work on my older phone too. It used to work on the bluboo the first days doe. Can I get any help plz?
Photo of Theodor Adrian Leahu
  • 322 Points 250 badge 2x thumb
  • confused
Posted 6 months ago
Was your previous phone an iPhone? If so make sure to deregister from iMessage.
Since 2 weeks yes, I just tried with my moms sim card who is with tellus and works without problems for the texts
What is the part I understand the less is that I can receive texts but I cannot send
Photo of Robert
Robert, Mobile Master
  • 103,148 Points 100k badge 2x thumb
Have you tries a new SIM card? Maybe yours is faulty?
Photo of Robert
Photo of Dinh
Dinh, Mobile Master
  • 31,796 Points 20k badge 2x thumb
As these phone are non-Koodo, have you set the APN to Koodo correctly?
https://www.koodomobile.com/help/setting-data-your-non-koodo-phone
I solved the probkem by myself. If you want to know: there the section SMSC number  in the sms settings. It was blank and i needed to put this number for koodo:+16475800172
Photo of Dinh
Dinh, Mobile Master
  • 32,650 Points 20k badge 2x thumb
yeah, there was one similar case in Public Mobile. However, it won't work with Android7, so I couldn't get the SMSC number myself.
okii thx for thge apn doe
