Self serve usage summary not showing data/minutes used
  • 2
  • Updated 2 years ago
Self Serve (online and mobile) says I have used 0MB of data and 0 talk time minutes, but when I click on the details it clearly shows the amount of data and minutes I have used.
Photo of Ross L.B. Laugher
Ross L.B. Laugher
  • 282 Points 250 badge 2x thumb
Posted 3 years ago
  • 2
Photo of Mathieu Carrier
Mathieu Carrier
  • 4,124 Points 4k badge 2x thumb
-Did you just start with Koodo? If so then it takes a few days for the SS to be updated.
-Did you maybe start a new bill cycle today? If so then self serve updates the usage every 4 hours.
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
Did your billing cycle just reset?
Data might need a little time to update.
And if you used your minutes only during "unlimited evenings&weekends", usage minutes show you 0 minutes but it show you all the minutes on the details.
Photo of Rod
Rod
  • 80 Points 75 badge 2x thumb
I have the same problem.  My Self Serve airtime dial indicator (summary) shows 25 of 500 minutes used, but when I view details it shows 116 minutes used.  I have been with Koodo for 3 months and I have 17 days left in the billing cycle.  Same for PC and mobile app.
Photo of Mayumi
When you view your details, it's showing total of your usage - includes evenings, weekends, family callings.
If your airtime indicator is showing 25 of 500 minutes, it means you used 25 minutes of daytime minutes. So, you have 475 daytime minutes left :)
Photo of Rod
Rod
Thank you :)
