Sd card not working
I have the Samsung discover. I recently just bought an 8g sd card. And I can't seem to get anything onto the sd card. Everything goes to my external memory, please help!
Photo of Allesha Cleveland
Allesha Cleveland
  • 660 Points 500 badge 2x thumb
Photo of John Burke
John Burke, Mobile Master
Have you tried it on your PC ensuring it's not the SD card itself that's the problem?
Allesha Cleveland
Yes it works fine on the computer. My hubby tried it in his phone. And worked fine for him!
Photo of John Burke
I'm not familiar with that particular device, but did you go into the storage settings & try mounting/unmounting it?
Failing that, I'd recommend you go to a Koodo shop & try one of their SD cards, or try one from your husband's device.
Allesha Cleveland
I mounted it and than unmounted it. And tried using my hubby's. His didn't work either. So im not sure what's going on.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,546 Points 100k badge 2x thumb
I'm assuming you mean everything goes to INTERNAL memory, since external memory would be the SD card, but can you confirm this?
Allesha Cleveland
Yes I mean internal memory!
Photo of rikkster
rikkster, Mobile Master
  • 68,350 Points 50k badge 2x thumb
Have you tried to format or re-format the microSD card? The option should appear under: Settings > Storage - there should be an option to Format SD card. If that option isn't available, you can try formatting the microSD card through your computer
Some brands of microSD cards work better than others, I use brands like Kingston, Lexar and Transcend, I'd stay away from lesser known or no-name brands. If my previous suggestions don't resolve the problem and you're within the 14-day exchange period, I would suggest exchanging the device.
