SD Card for Samsung Galaxy S5 Neo
  • Updated 2 years ago
SD Card for Samsung Galaxy S5 Neo. My phone strictly shows a place for a micro sd card under the battery. It looks like it should go directly under the SIM card, but it is blocked off. Any ideas why this would be?
Photo of Lisa Gagnon
Lisa Gagnon
  • 280 Points 250 badge 2x thumb
  • Frustrated
Posted 2 years ago
Photo of Robert
Robert, Mobile Master
  • 103,734 Points 100k badge 2x thumb
Could you post a picture so we can see? What do you mean blocked off?
Lisa Gagnon
There is no place to put the SD card. It shows where to put it, but there is no slot.
Photo of Nabil
Nabil, Employee
  • 6,640 Points 5k badge 2x thumb
Hey Lisa,
You should be able to put the SD card on top of the SIM card. This is not under the battery. Could you please double-check?
Thanks
Lisa Gagnon
I will double check. That's where I thought is should go, but it didn't seem to read it. I will try again though. Thank you!!
Photo of Nabil
Nabil, Employee
You're welcome Lisa.
Please click on this link for more info: http://www.samsung.com/ca/support/skp/faq/1098494.
Thanks
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,558 Points 100k badge 2x thumb
If it goes in and doesn't read you may need to format the card on the phone, just keep in mind this will erase everything OK the card so save everything important elsewhere first then transfer back to the card after its installed and working properly.
If it goes in and doesn't read you may need to format the card in the settings of the phone under storage, just keep in mind this will erase everything OK the card so save everything important elsewhere first then transfer back to the card after its installed and working properly.
