Samsung S II X - Flash
I use the S II X, I used to stream live TV on my cellphone, yesterday I was trying to watch a game and it did not work, I tried so many times that I was about to trow my phone away... What I don't understand is, that 2 weeks ago I streamed TV with no problems... Then I was reading that Androids with higher versions that 4.0.x do not support Flash anymore...
I know you guys are experts on this, any thoughts so I can continue streaming on my phone? Is is true that my phone does not support Flash anymore? Any workarounds?
Photo of Camilo_A
Camilo_A
  • 31,012 Points 20k badge 2x thumb
Photo of Jonathan I
Jonathan I, Mobile Master
There is a way to sideload Flash onto Androids. Was it a specific app or was it in a browser? Flash works on Dolphin.
Photo of Camilo_A
Camilo_A
It was in a browser, the one by default since I have not downloaded any so far... I will try dolphin to see if it works... Thanks
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
It's not 4.0 that doesn't support flash it's 4.1 Jelly Bean. Try using a browser called Sleipnir, it's in the Play Store and I use it to even use Flash in Android 4.1.2 & it works flawlessly.
Side note Flash will not work with Dolphin at all if you are running Android 4.1 Jelly Bean and above.
Photo of Camilo_A
Camilo_A
I tried already... Did not work... I will invest some time on it again to see if it works... Keep coming suggestions if more...
Try copying the flash player apk to your SD Card and then erase it from your phone then reinstall it from your SD Card to your phones internal storage. Then click on the Flash player app icon and set it up to not save any info from sites. then try it again. What site are you trying to stream video from exactly?
Photo of Camilo_A
Camilo_A
I found this... Do you think is something that could work?
http://forums.adobe.com/message/4675670
Photo of Camilo_A
Camilo_A
Ok... Confirmed for all those having issues with Flash on Android... Follow the steps on the link, It will work... Finally I can stream my games again!!!
