samsung s2 recieving MMS messages
i just switched from a blackberry to the samsung s2. my plan includes unlimited sms and mms messages but i cant send or recieve mms messages. i have my data turned off cause i use wifi. still shouldn't effect my messages. what gives ?
Photo of Candace Carter
Candace Carter
  • 90 Points 75 badge 2x thumb
  • sad
Photo of Sherlock Holmes
Sherlock Holmes
  • 5,004 Points 5k badge 2x thumb
MMS requires an active mobile data connection. You can't send or receive MMS over wifi.
Candace Carter
but if its unlimited then why do i need the data to use it? then technicialy it wouldnt be unlimited because its using the data ... or im just crazy
Sherlock Holmes
That's how MMS works on the HSPA network. It requires an active mobile data connection. It's unlimited in the fact that you do not pay any additional cost for sending MMS. Without unlimited messaging, it's $0.50/mms.
Candace Carter
okay thanks for your help!
Sherlock Holmes
Anytime and remember, always look towards the future :).
