Samsung phone cant send or receive picture messages
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: *611 or 1-866-995-6636 mentions
I have a samgung galaxy rugby phone from telus but on a koodo network. my data is on, but i still cannot send or receive picture messages. any suggestions?
Photo of Serena de Boer
Serena de Boer
  • 200 Points 100 badge 2x thumb
Photo of Camilo_A
Camilo_A
  • 31,072 Points 20k badge 2x thumb
Hi there Serena... Check if you have the correct APN settings, if not, update them and your phone should work...
http://koodomobile.com/en/ab/non-kood...
Serena de Boer
i have the correct apn settings, but my phone still cannot send or receive picture messages. when receiving it tells me to download the pictured but it never downloads and when sending it just keeps trying to send but never goes anywhere
Photo of Get it solved !
Get it solved !
  • 4,044 Points 4k badge 2x thumb
i guess that you also tried to power cycle your phone, and you checked that the right apn is selected (you should also see the apn of the OSP). At this point you have to call the tech support line by dialing *611 and chosing the option 5. They will perform a reset on your mms profil
Serena de Boer
what do you mean by power cycling?
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,132 Points 100k badge 2x thumb
To steal a line from 'The IT Crowd', "Have you tried turning it off and back on again?"
Photo of MatB
MatB
  • 32,458 Points 20k badge 2x thumb
Turn your phone off, wait few seconds, turn it back on, if it resolved problem, if not pull out Battery/SIM wait 1 minute, put back SIM/Battery and try again, if not working, select Koodo APN, turn Data on, try browser if you can browse google, if not working check your messaging centre number +16475800172 and try again
