Samsung Galaxy S II X not connecting to KIES
I had it working in the beginning, then suddenly my Samsung Galaxy S II X stopped connecting to KIES. I have googled this issue, and so far have had no luck with making it work again. I have uninstalled, reinstalled, USB debugging, changed USB port.
Just wondering if anyone else has had any luck with this frustrating issue?
Thanks,
T
Photo of Terri Moore
Terri Moore
  • 90 Points 75 badge 2x thumb
Do you have a pc or Mac? What version of operating system are you using (windows xp, windows 7). If it's windows xp you need to be running xp sp3)
Other than that there are a bunch of possible solutions here: http://androidforums.com/samsung-gala...
If one works make sure to post here which one.
Someone else may have an alternate answer too.
Photo of MykeC
MykeC
  • 20,174 Points 20k badge 2x thumb
Hey Terri, I do recommend contacting Samsung for assistance (http://www.samsung.com/ca/info/contac...). From a technical stand point, there isn't anything that our support team could do as this is a phone to pc issue so it's out of our support boundaries.
________________________
Photo of Paul Laplante
Paul Laplante
a. key in the dialer *#7284#
b. it has 4 option there..
UART (MODEM/PDA)
USB (MODEM/PDA)
c. For USB. select the PDA.if it already selected to PDA. reselect it by select MODEM and then PDA again.. Only change the USB setting.. andthen press back. try reconnect (thanks to napi1 @ androidforums.com/samsung-galaxy-s2-international/447145-sgs2-kies-not-syncing-os-2-3-5-a.html#post3484588)
