Samsung Galaxy S4 4.4.2 Connectivity Issue!
  • 35
I am using an Unlocked Samsung Galaxy s4. Model SGH-1337M. It was working completly fine on Android 4.3. But since i updated it to Android 4.4.2 last month I have been experiencing network issues. I am not sure if this problem is phone related or network related. I contacted samsung and they said they havnt recieved this complaint from anyone and said to try to change SIM cards. I experiencex some other laggs and bugs when i initially updated to 4.4.2 but those were eliminated after i performed a factory reset on the device. Only the connectivity issue remains. I will describe the issue in detail below.
When the phone is sleeping sometimes the network bars on the phone go to zero and the phone doesnt notify of having 0 bars or no connection but it seems as if the phone thinks there is network but calling/texting doesnt work. even when i go into settings to search for network it just stays frozen and also if i try changing network mode the settings dont change anything. The only solution that works is that i restart my device and i get the network bars again. There is no specific region this happens at. This is giving me major problems because I dont know when there is network and when there isnt unless i wake up the phone and check if there are barsm So i cant gurantee myself to recieve calls or texts while the phone is sleeping without verifying it every time.
Has anyone else experienced this problem? What can I do to fix it? Any help is appreciated.
I can show a screenshot of how the network bars are 0 if needed.
Photo of Amuk
Amuk
  • 576 Points 500 badge 2x thumb
  • 35
Photo of Jonathan I
Jonathan I, Mobile Master
I can't say I've experienced anything like this myself nor have any of my customers reported anything to me... but you could try asking Koodo for a $10 bill credit, then go to a kiosk that sells postpaid and buy a new SIM for your phone ($10 + tax) to see if that makes a difference in your service. It could be scratched up, worn out, or simply a dud.
Photo of Pedro Correa
Pedro Correa
  • 62 Points
I changed the SIM card 3 times
Photo of L Kot
L Kot
  • 80 Points 75 badge 2x thumb
YES! My phone just started doing this 10 days ago.Nobody can not reach me, my phone didn't even ring. I didn't get any texts either. It's so stressful when you're waiting for a very important call.Please advise how to fix this issue.
Photo of Allan LaFitte
Allan LaFitte
See my post on the second page. It should "fix" the problem until another update comes out. I also like Amuk Sandhu's suggestion about a custom update.
Photo of AaronD
AaronD
It's the rom root it flash it out problem solved
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,230 Points 100k badge 2x thumb
I don't have a SIM Card in my S4 right now so not sure exactly the wording they use but basically go into settings - more networks - mobile networks - and turn off LTE so it's running on HSPA Only and see if that does anything.
Photo of Areal Canine
Areal Canine
My S4 has started taking an hour to recognize a change in network. This started before the kit kat upgrade. Rogers says it is a phone defect.
Photo of Sandip K. M.
Sandip K. M.
  • 134 Points 100 badge 2x thumb
Hi. Rogers is wrong. It is not the phone defect. It's the Android 4.4.2 and there are a lot of bugs in 4.4.2. I have similar issue and what I do is to restart my phone and everything went to normal.
Photo of ewt00b .
ewt00b .
  • 90 Points 75 badge 2x thumb
i had the same issue before I updated to 4.4.2 so I think its more than the current update
Photo of spooky
spooky
  • 60 Points
i got a problem alike then 1 of my friend told me about http://www.wilsonamplifiers.com/ , n seriously it works
Photo of Amuk
Amuk
Thanks guys for the replies. I considered Paul's advice and changed my network mode to "WCDMA only" since about 2-3 days and I haven't experienced this problem again so far. I do loose the "LTE" connectivity with this and mobile data runs on a 4G network. I will let you guys know if it happens again under this setting.
Thanks!
Photo of Vickie Lawson
Vickie Lawson
YES! My phone just started doing this 2 days ago. My teen was at work calling for a ride home and my phone didn't even ring. I didn't get any texts either. Everyone and their brother was calling me but my phone didn't ring. I had no bars. I called Tmobile and they told me to switch my network from LTE/WCDMA/GSM (auto connect) to WCDMA/GSM (auto connect) while they work on the connection issue for 72 hours. All seemed fine. I woke up this morning to make a call and it wouldn't go through. NO BARS! Checked my network connection and none of the options were selected. I restarted my phone and bars were back. So it's losing connectivity for some reason. $650 phone! I am so aggravated! Never had this problem before installing 4.4.2 Kitkat!
Areal Canine
I am now post KitKat upgrade and have tried moving the connect choice to without the LTE option. Problem NOT resolved.
Rogers has sent me a refurbished phone. Better than nothing I suppose although I see it as the equivalent of a used car.
Early next week I will test the refurb where it will have to change provider and change back and see what happens.
  • 202,856 Points 100k badge 2x thumb
As far as your issue maybe it's with Rogers as I never had good experiences with them personally it was nothing but problems. I switched to Koodo and haven't had a single issue, heck I've never ever even had to call customer service or return anything at all in 3 years with Koodo.
Photo of Majella Owens
Majella Owens
  • 60 Points
living in ireland on the 3 network had problems losing data connectivity but when i switched to wcmda mode and not lte include it fixed the problem
Photo of mani bhushan
mani bhushan
Leaving in oman on friendi network&i had problem s lossing data connectivity &not working in wcdma mode please give a sugesson
Photo of Bhushan Sthapit
Bhushan Sthapit
  • 20 Points
I have the same issue in Singapore. Leaving the phone on 'WCDMA' mode only resolves the issue but whats the point of paying so much more for the LTE subscription and LTE handset if I can only use it on WCDMA mode? this is frustrating. if anyone knows the resolution to this issue, please let it be known.
Photo of Amuk
Amuk
Guys try selecting "WCDMA only" not "WCDMA/GSM(auto connect)".
  • 201,510 Points 100k badge 2x thumb
Exactly what I meant, you got it man. How's it working now is it still good?
Photo of Amuk
Amuk
Yup thanks a lot man. I haven't experienced it since then.
Awesome glad to hear. Have a great one Amuk
Photo of Yashvir Caussy
Yashvir Caussy
  • 60 Points
But this option is not seen in my phone pls help
I mean the WCDMA Only not available...
Available network in my phone is 2g/3g auto
3g and 2g
So which one of these three is the wcdma only
Photo of Amuk
Amuk
The issue might be due to the (auto connect) options in 4.4.2
Photo of Jay
Jay
  • 160 Points 100 badge 2x thumb
I am having this same issue on T-mobile with my S4 since the kitkat update. I don't want to have to sacrifice LTE connectivity... is there a better fix for this?
Vickie Lawson
Stupid Tmobile told me again over the weekend that they are not aware of any problem such as this with the 4.4.2 and that all bugs were fixed in March. Well I didn't download it until April! I told them about this site and several others proving it is not just a t mobile issue. They told me I have to factory reset my phone. Now I have to back up all my apps, pictures, and texts with another app. Then reset my phone. Use it for 2 days before adding in any apps, one at a time, for a couple days each. They want to make sure the software isn't being interfered with by any apps. Then I'd that doesn't work, I need a new phone! So friggen aggravated!
Photo of Jay
Jay
Vickie - yeah, that seems to be a logical course of action on their part. I'm not sure what else they can do. I called them yesterday, and they walked me through the standard APN settings, yada yada. I reset my APN settings before I called them, and they had me turn off the phone, then they refreshed the signal to the phone (provisioning, I guess - I'm not sure of the exact thing they did) and I turned on the phone again.
If the phenomena happens again today, I will post here to let you know. I feel like this is an issue with how the phone switches between different frequency bands. The phone seems to get "stuck." Definitely a software glitch... which might be remedied by a radio reflash or something; something I'm really not wanting to mess with, because I shouldn't have to. If T-Mobile wants to tell me to do it, I'll do it, but I doubt they will.
I'll update later...
Photo of Jay
Jay
Happened again. And in this state, if you go to select the "Network Mode" all the options are deselected. If you select one of them, it does nothing. The connection is "frozen."
Photo of Jay
Jay
I guess I'm just going to select "WCDMA Only" in the "Network Mode" settings to prevent my phone from having a frozen connection.
Sucks. T-Mobile is supposed to call me back today to follow up and see if I'm still having the issue. I'll discuss it with them.
Photo of Jay
Jay
FYI, this is what happens when the network connection is frozen - these options end up being deselected, and if you select one, it will still not work. You have to restart the phone.
Furthermore, the "4G" icon you see, with the bars, is meaningless. It is just frozen there, and not a real indication of a network connection.
Photo of Amuk
Amuk
Yeah exactly what used to happen, but my phone hasn't experienced that problem since over 2 weeks after I switched to "WCDMA only" option. i've experienced other problems such as random phone restarts after the update tho.. and I tried factory reset that didn't do anything.
Photo of Jay
Jay
Mine doesn't experience the problem either, with the "WCDMA only" option, until I travel out of my current location (i.e. my office) about a block away. It happened yesterday afternoon. So I rebooted the phone, and changed to auto, and I was in LTE. Basically, if you go through an area where the WCDMA coverage is spotty, and it loses it and has to regain it, the phone crashes. Sucks.
Photo of zak
zak
  • 60 Points
Mine too. Samsung Galaxy S4 mini (GT-I91956) updated to droid 4.4.2. Live in Austria. Had to switch to GSM only so phone would not crash and re-crash and crash and re-crash.. and crash and ....... are they competing with ms windows????
Vickie Lawson
Exactly!!!
Vickie Lawson
But if you restart the phone, the connection is back....until next time.
Photo of AaronD
AaronD
It's bugs in 4.4.2 root it flash it out problem solved
Photo of Jay
Jay
I made a post on the T-Mobile support forum too, here:
http://support.t-mobile.com/thread/68518
Maybe someone will see it and a good solution will be posted. Who knows...
Photo of Jay
Jay
Something tells me that the 4.4.3 update (yet to come) will fix this.
Check out this article:
http://www.androidpolice.com/2014/03/...
Guess we'll wait and see. The article references "frequent data connection dropout fix" which may be related.... who knows.
Bottom line, it seems, is that you may as well not do a master reset until we get an updated software version. Resetting the phone and re-installing all your stuff seems like a waste of time until 4.4.3 is released.
Photo of Jay
Jay
To update this; the "WCDMA Only" option didn't solve the problem yesterday.
So, I guess waiting for 4.4.3 is the only option. Bummer.
Photo of brian mcnish
brian mcnish
Did anyone ever have any luck with this? I have the exact same issue. I tried resetting, switching to WCDMA only etc. TMobile has even sent me a new S4, I got a new SIM and nothing helped at all. I can't see sticking with them now that I have a phone I can't ever rely on.
Areal Canine
I did try changing the settings as suggested above, none of that worked.
I received a refurb about a 2 months ago. So far so good. It works as advertised.
I believe the fault to be with Samsung and the building of the phones......good help is hard to get....
Vickie Lawson
All of a sudden my issue stopped. I haven't lost service or connection in months....Don't know what they did because I never did hear back from Tmobile tech support. I had the issue for weeks.
Photo of Carmine Iacullo
Carmine Iacullo
I have the same exact issue and even received a replacement phone from T-Mobile. Done all the recommended fixes, but it still doesn't work.
brian mcnish
I had a higher up TMobile tech get back to me today. He told me that they have confirmed that there is an issue with the S4 and Android 4.4.2. He told me the ONLY way to resolve it currently would be to switch to 2G data only! That is crazy and makes my phone pretty much useless for anything besides calls and texts. He said switching to 4G might make it better but wouldn't solve the issue. He said they have no idea if/when it'll be fixed.
Also when i was at the mall earlier i stopped by a TMobile store and a rep there told me that they have been getting a lot of complaints about this but currently couldn't do anything about it. It blows my mind that nobody is doing anything about this.
Photo of rikkster
rikkster, Mobile Master
  • 68,218 Points 50k badge 2x thumb
Head over to SamMobile and download the firmware for your device. Make sure the firmware matches the country of origin for your device. Within the firmware download page, there is a link to Odin which is the file flashing utility used to install firmware. You must register first. Registration is free and so is the firmware download. The model number to search for is: GT-i9515.
http://www.sammobile.com/firmwares/
All I can do is make calls and text! No multimedia messages, tho... Can connect to my email, the Internet! I did the switch to WCDMA only, but it didn't do a thing! I down loaded 4.4.4 and it has been wicked every since! HELP! :-(
Photo of rikkster
Mobile data needs to be enabled in order to send MMS or multimedia messages.
Photo of Sam Kumar
Sam Kumar
  • 72 Points
could it be because you have to enable the wifi calling feature ?
Photo of Sam Kumar
Sam Kumar
  • 72 Points
The Jellybean update has messed my phone, pretty good!
Carmine Iacullo
How about a class action lawsuit? This issue is getting very annoying!
