Samsung Galaxy S3 Telus To Koodo Help Please
I have a telus galaxy S3 its locked onto telus. Is unlocking it to koodo as simple as buying a Koodo Simcard, Cutting it down to mini, putting the card in and then entering unlock code ? Please Help
Photo of Derick Wilhelm
Derick Wilhelm
  • 160 Points 100 badge 2x thumb
Koodo sells mini sims
You may or may not need to unlock it to use it with koodo. Best option is to bring it to a kiosk and ask for a tester sim. If it works you're golden. If not you'll need to unlock it.
To unlock it you'll need to purchase an unlock code from either Telus or a 3rd party like gsmliberty.com. Check telus's policy about unlocking as some carriers state 3rd party unlocking may void the warranty.
Photo of happy....
happy....
  • 798 Points 500 badge 2x thumb
You don't need to unlock it if from Telus I did it.
just put Koodo sim card in and set APN to Koodo.
