Samsung Galaxy S3 (SGH-I747M) - LTE/4G Network Data not working
  • 2
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: *611 or 1-866-995-6636 mentions
So I bought a used S3 about 3 weeks ago and I unlocked it with at a local shopping mall. I got my old contract on it and it worked perfectly fine until yesterday.
I installed Cyanogenmod on it because a friend of mine recommended it for me. After having played around with the installed software (didn't encounter any problems whilst installing it) I decided that I liked the stock OS better so I downloaded the stock file (JellyBean 4.3) and I reinstalled my backup on the device but I am now having a big issue for me:
I cannot seem to be able to active the Network Data, I use it a lot and it is really bugging me.
I think I might have installed the "Telus" version of Android JellyBean 4.3 but remember reading that it was compatible with Koodo Mobile and their networks.
Help?
Photo of Samuel L.
Samuel L.
  • 142 Points 100 badge 2x thumb
  • 2
Photo of Jonathan I
Jonathan I, Mobile Master
Do you have the correct APN settings in the phone?
Photo of Samuel L.
Samuel L.
After some research I realized that I had to add one since it only gave me two Telus APNs by default. These are my settings:
Photo of Jonathan I
Proxy is incorrect. Make sure these are what you have in your phone and try again:
APN: sp.koodo.com
Proxy server: 74.49.0.18
Port: 80
Username:
Password:
Server:
MMSC: http://aliasredirect.net/proxy/koodo/...
Port: 80
MCC : 302
MNC : 220
APN type: default,mms,supl
This helped me with an LG G3, thanks!
Photo of Samuel L.
Samuel L.
Wow! Thanks a lot it fixed my problem!
One question thought: I used to have "LTE" icon for connection and now I see a "4G" icon instead. I heard that they are the same but I just want to make sure. And if not does it just vary from where I am? As I heard some regions don't necesseraly get for example 4G connection but only 3G.
Thanks in advance!
Photo of Jonathan I
H+ is up to 42 mbps.
Photo of Samuel L.
Samuel L.
thanks!
Photo of Maksudur Rahman
Maksudur Rahman
how can i active 3g connection in this phone?
Maksudur Rahman
sgh-i747
Photo of Jerjer Magallanes
Jerjer Magallanes
  • 60 Points
My s3 can only get edge connection.
Any idea how to get lte or just the H connection?
Photo of Michael J O'Leary
Michael J O'Leary
  • 782 Points 500 badge 2x thumb
*#272*Phones IMEI Here# <<-- Csc Sales Code
here u fix dial from phone
Photo of Muhammad Naeem
Muhammad Naeem
  • 60 Points
I have s3 i747 in pakistan its 3g is not working plz anyone help me
Photo of BobTheElectrician
BobTheElectrician
  • 67,578 Points 50k badge 2x thumb
If it's a Koodo phone, you have to enable Pay per use International Roaming for anything to work there at all. You can do it on self serve, or *611.
Photo of Dan Thane Tweyman
Dan Thane Tweyman
  • 60 Points
So I Just went through this, and I can get 4G (and LTE) now. But it still doesn't seem to want to let me do MMSes. Any thoughts?
Photo of Roger Lai
Roger Lai
  • 60 Points
Hi there, I just got a Koodo plan and I have the exact same problem as Dan - MMS'es don't work. Data works (same phone).
What is going on?
