Samsung Galaxy S2 X sound problem
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 1-866
Samsung Galaxy S2 X, I cant hear the other party when calling someone.
The phone has been working working perfectly fine for the last two months but all of a sudden it giving me a trouble hearing the other person during a call.
Photo of LikeaBoss
LikeaBoss
  • confused
First try a soft reset of your phone (take out the battery, sim, micro sd etc for multiple minutes. If that should fail, try a factory reset, which can be done from settings>privacy>factory reset. If these fail it is a hardware issue and cannot be fixed without a technicians help.
Photo of Camilo_A
Camilo_A
  • 31,746 Points 20k badge 2x thumb
Just be careful when it comes about factory reset, you should back up your info since will be deleted
Photo of Stashiv
Stashiv
Factory Reset should be a final step, if audio works in other applications it may be simply a setting/volume issue.
Photo of Stashiv
Stashiv
LikeaBoss do other applications have similar sound issues or is it just when placing or receiving a call?
Photo of Katie Hill
Katie Hill
  • 60 Points
Does it work on speaker or with a headset? I had an issue with my old phone, and it turned out that the speaker was busted.
Photo of LikeaBoss
LikeaBoss
I tried the factory reset, didnt work :(
There are no sound issues with the other applications and it works perfectly fine with a headset or on speaker.
The phone is nearly two months old so seems like I will have to send it back to the company to get it fixed.
Photo of rikkster
rikkster, Mobile Master
Call Koodo tech support from a line other than your S2x, they may be able to further troubleshoot or assist you with sending your device in for repair.
Koodo's number: 1-866-995-6636, press 6 or say "technical support".
Photo of Emilie Levac
Emilie Levac
  • 60 Points
I have a samsung ace but I do have probleme with the sound... I can hear clair but peaople cant hear me...
Photo of rikkster
Call Koodo tech support from a line other than your Galaxy Ace, they may be able to further troubleshoot or assist you with sending your device in for repair.
Is your mute on accidentally?
Photo of LikeaBoss
LikeaBoss
umm not sure, how do I check that?
Photo of rikkster
Swipe from top of screen downward and look for the speaker icon with a hash mark through it (second icon from the right). For Sound to be enabled, the icon should be greyed out and display the word Sound. By tapping the icon, you can cycle through Sound, Vibrate and Mute modes.
try this too
Go to: Settings > Sound > Volumes - all sliders should be at or near maximum levels. In the same Sound window, tap on Silent Mode and set to off.
