Samsung Galaxy S11X Charge Will Ya??!!
I have a Samsung Gallaxy SiiX. For the most part it has worked well for the past year. Just lately it kicks in and out of charging mode. I tried a new charger - it's still acting the same. Options?
Photo of Vaughn Palin
Vaughn Palin
  • 80 Points 75 badge 2x thumb
Photo of John Burke
John Burke, Mobile Master
Is the USB connection lose?
Meaning, can you wiggle it around or is it tight?
You might want ti try a charger with a longer tip, that's what I did when I had charging problems. Typically a cable from Motorola or HTC have longer tips than others.
Vaughn Palin
It is the phone end. The USB end seems OK. I have to push the charger into the phone, and wiggle it up and sideways to get it to charge. Then it sometimes will charge for a bit.
Photo of Ivan
Ivan, Mobile Master
Sounds like a charging port issue. As it's probably out of warranty, I suggest taking it to a local repair shop. It should be less than $50 to fix if I recall correctly.
