samsung galaxy ace wont text (NOT DATA PACKET PROBLEM)
samsung galaxy ace cant recieve or send text but can call both ways..... no it is not the data packet thing..... getting tired of all the problems with this phone and/or koodo.
Photo of Hayley Travis
Hayley Travis
  • 80 Points 75 badge 2x thumb
  • pissed
Photo of Josh765
Josh765
  • 1,344 Points 1k badge 2x thumb
Hi Hayley,
I'm sorry you're having so much trouble.. I don't have a lot of experience dealing with texting issues but is your message centre number +16475800172? (Under the message app, tap menu button, then tap settings and scroll down)
Photo of MatB
MatB
  • 32,478 Points 20k badge 2x thumb
furthermore you should get rid of unwanted messages in your inbox, increase SMS/MMS limits, check delete old messages and auto-retrieve in your SMS settings, if not working reset your phone settings to factory default settings, regarding your remark on (Not Data Packet Problem) her is a post where it was discussed for Galaxy Ace http://community.koodomobile.com/kood...
Photo of Get it solved !
Get it solved !
  • 4,044 Points 4k badge 2x thumb
Before performing the reset to factory state, it is better to call Tech support to have your SMS profil checked if it is well set up . Do not forget if the solution is a reset to default settings to backup all your data by using Samsung Kies.
