Samsung Galaxy Ace 2x will NOT send or recieve messages, and I have service.
  • 3
My samgsung Galaxy Ace 2x phone that I recently bought is having trouble sending and recieving messages. I have service, but when i try to send a message it just says "Failed". I'm not sure why. It did this before on my last phone (a blackberry) occassionally, but its been a couple days sense this phone has worked properly. HELP PLEASE.
Photo of Kassidy Wright
Kassidy Wright
  • 90 Points 75 badge 2x thumb
  • sad
Posted 6 years ago
  • 3
Photo of PD
PD
  • 6,798 Points 5k badge 2x thumb
Did you try restarting the phone?
Photo of John Lee
John Lee
Is packet data turned on? The Samsung Galaxy Ace's won't seem to send messages if the data is turned on. I don't know why but it's a well known bug that many users face unfortunately. If it is on, try turning it off and sending a text message. It should work.
Photo of Jenn Ertel
Jenn Ertel
  • 80 Points 75 badge 2x thumb
Did you figure out the problem? I'm having the same issue with my prepaid Samsung Galaxy Ace. I get the 'failed' message when I'm outside of wifi but it was working when I was around wifi areas. Now it won't even send in a wifi area. It says 'sending' when the network becomes available. Ugh!!! Let me know if you figured it out please! Thanks alot! :)
Photo of Jenelle Robinson
Jenelle Robinson
  • 60 Points
i have this same issue :(
Photo of rikkster
rikkster, Mobile Master
  • 68,330 Points 50k badge 2x thumb
This is getting a little ridiculous. Samsung really needs to fix this problem and Koodo should thoroughly field test equipment prior to selling it.
While this is an annoyance, the workaround is simple. Install a data toggle widget on your home screen. This will save you time from having to go through the menus to turn data on and off each and every time you want to send a text message. Keep in mind MMS messages (messages that include pictures) require data.
There are plenty of data toggle widgets out there, here is one example:
https://play.google.com/store/apps/de...
Hard resetting or pulling the battery will in most cases temporarily correct the issue of losing Wi-Fi connectivity. If this is happening with your home wireless network, reboot the wireless router and and configure the router to allow the Ace to become a preferred device via MAC address, this will fix the Wi-Fi connectivity issue.
Clearing out your text message inbox is another remedy as the Ace limits itself to how many messages can be stored per conversation. The minimum default value is 20 messages per conversation, the maximum value that can be entered is 5000.
I wrote this article a year ago, hope this helps.
http://community.koodomobile.com/kood...
Photo of RedMageX
RedMageX
  • 2,908 Points 2k badge 2x thumb
Another toggle widget I'd reccomend is Power Toggles. Does more than just data networks (eg. wifi, sync, brightness, etc), and the widget is customizable also.
https://play.google.com/store/apps/de....
