Samsung galaxy ace 2 x issues
  • 4
My phone stoped working it just shut off on me and now every time I turn it back on it just shows GT with a bunch of numbers but won't load further?
Photo of Ethan Petzak
Ethan Petzak
  • 90 Points 75 badge 2x thumb
  • 4
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,456 Points 100k badge 2x thumb
Not a good sign. I assume you gave it at least 5 minutes? If so, you may need to do a factory reset on the phone. This will erase all information stored on the phone, but might get your phone working again.
Remove battery, sim card and sd card
Put just the battery back in.
Hold down the home button and the down volume while you power the phone back on. Do not release these buttons until the phone enters recovery mode.
From the recovery menu, use the up/down volume to select factory data reset, use the home button like a mouse button to click on it.
Once the reset is done, click on reboot now.
Hopefully the phone will be working again.
I HAVE THE ISSUE, BUT MY PHONE DOESN'T RESTART OR DOESN'T GO TO RECOVER MODE. TELL ME DO YOU HAVE ANY ALTERNATIVE FOR THIS PROBLEM,, THANK YOU
how? i have this problem..
Photo of Mayumi
Mayumi, Mobile Master
  • 114,562 Points 100k badge 2x thumb
Did you try rikkster's suggestion?
If it didn't work, you can bring your phone to the nearest koodo shop and ask them if it can be sent to the warranty repair . If you can't use the warranty, you can check the nearby repair shop. Or it may be better to upgrade your cell phone. :)
Photo of Dan Vandersteen
Dan Vandersteen
  • 60 Points
Dang it, I have the same problem! Did anyone ever find a solution???
Photo of rikkster
rikkster, Mobile Master
  • 68,238 Points 50k badge 2x thumb
The above mentioned method puts the Ace 2x in Download Mode and not Recovery Mode. To enter Recovery Mode do the following:
1). Remove battery
2). Install battery
3). Press and hold Home button, press and hold both volume Up/Down buttons, press and hold Power button. Keep holding this button combination until the GT-S7560M logo appears and release the Power button, but continue pressing the Home and volume Up/Down buttons until a green Android robot appears.
4). Let go of the Home and volume Up/Down buttons buttons and you should see the Android System Recovery menu (in blue text).
Use the volume Up/Down buttons to scroll through the menu, use the Power button like an 'enter' key to select the desired operation.
5). Scroll down to and select 'wipe data/factory reset', using the volume Up/Down keys and the Power button.
6). Scroll down and select 'delete all user data'
Allow the device to go through the factory reset process. The Ace 2x should revert back to the Android System Recovery menu, press the Power button to 'reboot system now' and the factory reset is now complete.
Photo of Kayla Mokren
Kayla Mokren
  • 60 Points
the logo never shows and i tried all steps?
Photo of Melanie Hetz
Melanie Hetz
  • 62 Points
hey so i have the same problem is there any way to keep the data i have on my phone?
No I'm sorry, a factory reset wipes the phone
I'm sorry you don't like the solution, but it is what it is.
With all due respect, the samsung galaxy ace 2 sold for $150, even it was brand new. Most good quality smartphones retail in the $300-600 range. You did not pay 'a heck of a lot of money'.
Photo of Lisa McGrenere
Lisa McGrenere
the last post we followed all the instructions but the phone still shuts off as if the battery is dead. when plugged in the battery life is shown full or close to it.
Photo of rikkster
  • 68,186 Points 50k badge 2x thumb
Sounds like you need a new battery. If you unplug the charger and the battery level reads zero, or the phone itself shuts off or fails to power on, it's likely the battery that's at fault.
Lisa McGrenere
once the phone is plugged in and you turn it back on, the battery level reads a full charge (ie. 91% or whatever it may be at) the battery has been tested which shows it has full voltage.
Photo of tennyone
tennyone
  • 60 Points
I met the same case before on my HTC, but it waw normal after I restarted it.
Photo of Samantha Whaley
Samantha Whaley
how would i go about getting a new battery for my Samsung Galaxy Ace 2x
Photo of Jackie Poire
Jackie Poire
  • 60 Points
Go either ebay.ca or cellphoneshop.net. Either place has great prices. :D
So, my power button broke on my Ace 2x, but other than that it works fine. The problem is, the battery died and now I can't get it to turn back on. The last time this happened, I plugged it in, and pulled the plug back out after 3 seconds and then it turned on. But this time, it's not working. I kept reading that I had to hold the volume buttons and home screen button in so I could get to the reboot menu to (obviously) reboot it. The problem with that is you have to select reboot with the power button, and my power button doesn't work! Can someone please help me?
There is no way to make the phone power on if the power button ddoesn't work. You'll either need to get the power button fixed or get a new phone.
Photo of michelle from hell
michelle from hell
  • 80 Points 75 badge 2x thumb
i went through the reset options and now that i'm trying to set my phone back up it just keep shutting off and restarting.
Photo of Amelie Sarah
Amelie Sarah
  • 82 Points 75 badge 2x thumb
My phone keeps shutting on and off even after a factory reset. It does this especially when turning on the wi-fi. that immediately shuts it down. Battery appears to still be good, it charges and is full.
Amelie Sarah
So for those of you having problems with your Ace even after the factory reset, I went to have mine fixed and the guys said that it was dead. Nothing can be done :(
Photo of Angel Klodt Rhb
Angel Klodt Rhb
Mobile Master Rikkster you are AMAZING!! Even Samsung live chat didn't get this right! They told me to hold only the volume up button with home & power which did nothing! Tried your steps & VOILA! Recovery mode!! GENIUS!!!
Thank you!!!
Photo of rikkster
You're very welcome Angel!
Photo of Brittney gentles
Brittney gentles
  • 60 Points
so my phone is slow with text and open up app's, is there a way to fix that??
Photo of rikkster
If it's the Ace 2x, I would recommend an upgrade. The only way to bring back the performance of the Ace 2x is to factory reset the phone and even that is hit or miss. It was an okay phone for its time, but you may want to check out some of Koodo's latest phone offerings. The Moto G 3rd Gen is an affordable and reliable phone that might be worth considering.
Moto G 3rd Gen
https://www.koodomobile.com/phones/mo...
Other Koodo phones
https://www.koodomobile.com/phones?IN...#
Photo of matt
matt
  • 134 Points 100 badge 2x thumb
Factory reset will be the only way to solve... Sorry, an upgrade would also be a smart idea, the phone is out of date and it may be best to go with something new. No problems will occur with a brand new S6!!!
Photo of rikkster
Not everyone can afford a top of the line flagship device and there's nothing wrong with that. People have to work within their budgets. What works for you may not work for the next person, so it's best to keep options open.
Since you're kinda new here Matt, a few words of advice. Try not to repeat what someone else has already said. It doesn't go over too well here. Thanks.
