Samsung ace 2 keeps Freezing
  • 2
My samsung ace 2 frezzes a lot ! And i have to keep restarting over and over again ! Any way that could stop?
Photo of Kristi Brar
Kristi Brar
  • sad
  • 2
Photo of samsvoc
samsvoc
  • 7,686 Points 5k badge 2x thumb
Try a battery pull and if that doesn't help, a factory reset should.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,524 Points 100k badge 2x thumb
Are you closing apps fairly frequently by holding down the home button & flicking the apps that pop up in a list to the side.
Photo of Bob Smith
Bob Smith
  • 1,492 Points 1k badge 2x thumb
My ace 2 freezes at times and lags a lot. It's just a weak and low end phone and not sure if you can do much about it.
Photo of PD
PD
  • 6,798 Points 5k badge 2x thumb
Clear cache as Kid suggest frequently.
Download & run these apps when you experience severe lag.
https://play.google.com/store/apps/de...
