Samsung s7 keeps freezing
  • Updated 5 months ago
  • (Edited)
Hello I just bought a Samsung S7 yesterday and it keeps freezing and rebooting. When I first turned it on it did this about a half dozen times before I pulled the battery out. I literally just bought it and am wondering why it keeps freezing and rebooting? Some of the things it freezes on are videos, facebook, and games. Sometimes it does it when I am not using apps.
Photo of Lotus
Lotus
  • frustrated
Posted 5 months ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
I'm confused, you say you pulled the battery out but the Galaxy S7 does NOT have a removable battery it's a glass front and back. What phone do you actually have and where did you get it because it's not a galaxy S7?
Photo of Lotus
Lotus
It is just a samsung S7 not a Galaxy
Photo of Goran
Goran, Mobile Master
  • 91,192 Points 50k badge 2x thumb
The s7 is only as a galaxy. There is no non galaxy s7. Are you sure you got the Samsung galaxy s7 or did you get a lower end Samsung phone?
There's no such thing as a Samsung S7 that's not a galaxy S7.... Can you post a picture or give us the model number from the box?
I don't even think Koodo carries any Samsung phones right now that have removable batteries do they?
Photo of Lotus
Lotus
Ok double checked it is a Galaxy S7 I also asked my friend who was helping me he said he plugged it in and rebooted it because he could not find the battery to pull. He told me at first he was going to pull the battery. When I bought it it just said Samsung S7 so I didn't realize it was a Galaxy. Sorry for the confusion.
Photo of Goran
  • 91,254 Points 50k badge 2x thumb
Did you also buy it new from a store or used?
Photo of Lotus
Lotus
New from The Koodo Store
Photo of Goran
You can attempt a factory reset to see if that helps the problem. If not, you should take it back to swap it if it's been less than 15 days and warranty repair if over.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,242 Points 100k badge 2x thumb
Not sure if the policy has changed, but you used to be able to return and exchange for any model within 15 days, and replace with the same model within 30 days. Anything beyond that had to go through the manufacturers warranty.
Photo of rikkster
rikkster, Mobile Master
Do you recall whether or not your Galaxy S7 was performing an Android system update?
It's possible that given this is a new Galaxy S7, it might have been in the midst of downloading or installing an Android system update. If the system update is interrupted, the phone could exhibit the symptoms you describe, (e.g. bootloop, freezing). Generally, there's plenty of information displayed on-screen to notify the user of a pending update.
I second the factory reset method. A factory reset does a lot more than just turning the phone off and back on again. Hopefully this resolves the problem. Keep us posted.
