Samsung S7 Battery Life Expectancy
  • Updated 6 months ago
I have a Samsung S7 that is 11 months old.
Originally, when I got the phone during the first month I could go 24 hours on a single charge.
My phone is now 11 months old. My battery charging expectancy has now dropped to 8-10 hours. Its not uncommon to see my battery life decline 10% on average per hour. The back of the phone also gets hot.
What might be the problem with my battery? What should be my next action?
Any advice would be appreciated.
Thank you!
Photo of Ted Sims
Ted Sims
  • 454 Points 250 badge 2x thumb
Posted 6 months ago
Photo of Goran
Goran, Mobile Master
  • 83,220 Points 50k badge 2x thumb
Could be a faulty battery if it's getting hot when it never used to under regular usage. You can send a private message to Koodo via Facebook Messenger or DM via Twitter to start a warranty process if you want to find out what exactly is wrong.
Photo of Cory
  • 10,442 Points 10k badge 2x thumb
It could be a faulty battery, or an app/process constantly running in the background.
I would start with backing everything up and then doing a factory reset. If the issue persists after, then it's hardware related. At that point, I would look into warranty repair.
Photo of rikkster
rikkster, Mobile Master
  • 66,412 Points 50k badge 2x thumb
My second S7 is only a couple of months old and it too gets hot from charging. I suspect that the quick charging adapter is the culprit. The charging adapter itself gets very hot. As a precaution and possible suggestion, switch to a Samsung adapter that doesn't have the quick charge feature. The battery and charger will stay a little cooler while charging and should extend the overall life of the battery.
I agree with all of the recommendations mentioned. A battery losing capacity that quickly is usually a sign that the battery will need to be replaced. You're still within the manufacturers one-year warranty period, may as well take advantage before it runs out.
Photo of Jan Hope
Jan Hope
  • 4,336 Points 4k badge 2x thumb
There could be many reasons for this but  I am surprised that Samsung's battery would deteriorate so quickly.
I actually wouldn't be surprised if that was iPhone battery. I know some folks that have to charge their batteries on IPhone 3 times a day.  Just leaving their phone on stand-by over night discharge battery totally.
